my forward slash key is stuck on startup
patronus
Visitor
:slight_frown: hey guys i'm really feeling miserable :cry: . for a while now each time i startup my computer, (sony A117S) the forward slash key acts as if its stuck and its a real pain trying to type in my username and password before logging in. There is nothing under this key cos i have checked it several times its just as good as the rest. Nothing has been spilled on it either.
what i noticed however is that whenever this key is acting stuck, my mouse pad ceases to 'tap to click'. i dunno if these two things are related.
i have recovered my pc twice now cos of this problem and i dunno what else to do. I have installed most of the updates on the sony support website.
i have put the question to the e-support team and replies from them are really slow plus the site has been down for like 398years now..lol.
Neways any form of advice would be much appreciated.
4 REPLIES 4
rich912
Contributor
In order to rule out a hardware problem, start you computer in DOS mode and see whether the '/' key works. If it does we can then start to look for Windows issues.
Go n-éirí an bóthar leat
profile.country.en_GB.title
kee-lo_
Member
Some compressed air on the key might do the trick, it only needs to be a speck of dust
patronus
Visitor
the same problem occurs in Dos mode so i guess its a hardware issue. I will try out some compressed air tomorrow.
rich912
Contributor
Yes, sounds like it:smileysad:
Good luck with that.
