PowerDVD for Vaio
profile.country.en_GB.title
minoltatosony
New
PowerDVD for Vaio
Some DVDs generate an error code F4D41436 the details being 'The copy protected disc can not be played when the TV out function is enabled. How do you disable the TV Out port on PCV-RZ221 with GeForce4 Ti 4600 video card?
1 REPLY 1
mathrobe
Visitor
i started to get this error after i put in a 5.1 sound card so i went to the power dvd web site and found out that the version of power dvd was version 4. this only supports the onboard sound with the two speakers(stereo) that came with the pc. some dvds come with a player that you can load to your pc. the one i got was with a harry potter dvd ( interactual player) so i use that now.if you want to use power dvd with multi channel sound you will have to upgrade to power dvd 5.hope this helps.
