Pioneer DVR-K16D and Samsung DVD+R DL
922330
Explorer
Hi,
I bought this week my Vaio VGN-FS315B and wanted to test my DVD-burner with a Dual Layer disc. I went to a shop and bought the Samsung pleomax DVD+R DL 2.4X. After inserting the emty media in my Vaio, it does not recognise my disc. I tried it with 2 disc without succes.
I use NERO 6 to burn and following the info of Nero, my DVD-burner is a Pioneer DVR-K16D. A firmware update is nowhere to find.
Has anyone also problems like this and maybe what can I try to to fix it, or do I've to live with it?
2 REPLIES 2
Blencogo
I can't afford the discs to try it out!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
salo
Visitor
Hi...
I had the same problem... If you had solved the problem please inform me asap...
Many Thanks;
Salo
