Hello,
I bought a Vaio PCV-RXM22 (in Germany). A Pinnacle PCTV Sat card doesn't run in this computer. By starting the TV software the XP problem reporter stops it with the information ModName: ivivideo.ax ModVer: 3.1.58.5 at Offset: 0001404f. The card is put in slot three. The OS don't registers any conflict.
Thanks for help,
Gert Meng-Wacker
Try going to Pinacle's website and look for an update, or change its PCI slot.
Hello Mr Kee-Lo,
thank You for the answer but Your idea I tried already. In one slot, I think its number 3 (the lowest slot) no IRQ sharing appears. Unfortunetly Pinnacle hasn't new drivers.
Regards
Gert Mneg-Wacker
Damn, well, I would drop them an e-mail, see if they have any solution. Tell them Sony don't support it, so could they give advice.
Thats one thing I hate about technical support - one won't help because its 3rd party hardware, when another company won't support it because its a PC they didn't make..... sigh.
Try the following:
take the card out, start your machine, and uninstall any InterVideo-software (e.g. DVD Player). They have some files that interfere with TV-cards.
Let me know if that helps, please!
Regards and good luck!
David
