One Dead Desktop
stevep-4
Visitor
One Dead Desktop
:cry: My RX-405 has died.
History.
Thursday put machine into "standby" while I popped out. (!st time to use standby in XP)
machine would not restart by keyboard astivation.
Restarted computer by full power off/on.
Since then, computer would stop and reboot whenever it felt like it.
Saturday, XP would not load fully. only 3 icons completed (IE6, Outlook). Managed to save e-mails to Memory stick.
Performed system recovery using Vaio disks.
Sunday. Computer continued to stop at will.
Tried performing system recovery again......"Check Sum Error in F:\\SONY.IMG
I have tried also using the E drive (DVD) with same effect.
Repeated attempts either give this message, or "Incompatible Image in use"
SO, what are my options?? John Lewis have given up, but suggest that I call Sony to get a new set of Disks. But from reading messages on here, sony don't give out new disks, EVER !!
I am not a happy bunny......2 weeks hard work on the D drive (partition of C), and I fly in the morning !!!
11 REPLIES 11
Hi,
Not sure but it may be possible that you have a virus that is progressively corrupting your machine. Try some antivirus software, it may be able to tell if this is the case and possibly remove the bugger.
If not then you need to try and format the machine, possibly from something like a DOS/ Win 98 boot disk. Then run you system restore disks (assuming they won't run currently). If you format C: you'll be able to load an Operating System however if it was caused by a virus on the 😧 then that will need formatting as well.
Failling that, I have no idea, maybe a hardware/motherboard failure. :slight_frown:
stevep-4
Visitor
I ran Norton virus checker on it the other day, and that is as upto date as can be. (I get auto notification of new anti-virus definitions).
I don't think you an run an anti-virus software if there is no operating system there...(system recovery deletes this before it loads up the new system)
If I had dos, or other software, I would probably lose the info on the D:\ partition, and possibly have trouble with sony.
Will call sony in the morning, and see when they are going to pick it up. (Like all Computer suppliers, they will blame the software and reccommend a complete system recovery...which doesn't work).
Liek you say, it is possibly a motherboard failure, or maybe it is a corrupt CD....
stevep-4
Visitor
Sony says they reckon the hard drive is at fault....and I must return the unit (next time I am at home).
SO, I store all my data on the D:\\ partition. is it possible to pop the hard drive into another computer and access the D:\\ partition? If so, how do I go about it??
I'm not certain about your particular model, but I think that the D:\ is a logical partition on the same physical disk as your C:\. So you won't be able to seperate them.
If they are on seperate physical disks then you should be able to remove it and use it on another machine, although this may not be straight forward.
profile.country.en_GB.title
kee-lo_
Member
I would call Sony - tell them all you told us, they should be sorting it out for you, as its brand new. I have a feeling the BIOS might have had issues.
chuckalicious
Visitor
Yeah, sounds like a hardware fault. I work in IT myself and have seen this kind of thing. A rebuild of the machine normally does not help. Yes, I would imagine your C and D drives are one and the same, just 2 partitions. You could still try to remove the dirve and set it to slave mode and put it in another PC, but it'll have to be running XP or Windows 2000 to read NTFS file systems (assuming I read right and you are running XP).
I would let Sony deal with it, although I am surprised John Lewis have not just swapped it out, they have always done that with me.
Good luck.
VAIOspecialist
Visitor
Sorry to hear about your problem!
You only have one physical harddisk, formatted with NTFS. You can take out the harddisk very, very easily, and pop it into any other computer. Here is an article from another member on that:
Reading the files from an NTFS disk plugged into a different computer is not a problem unless the data has been encrypted. A handy little freeware utility will even allow you to do this on DOS/Win 3.1/9x and it is available from http://www.ntfs.com/products.htm
But that might not even be the reason of your problem. Another problem might be your Memory. In case you have a friend that can borrow you another bank, I would try that...
Good luck,
David
chuckalicious
Visitor
Yeah, memory could be a problem. Out of interest, is Mr Vaio Specialist a real specialist (ie work for Sony). Anyway
Yes, memory problems can cause these kind of problems, but then so could many other problems.
I just thought that it may be a particular process that is causing the machine to crash.
You say you can get as far as maybe 3 icons, suggesting that XP is okay until it gets to that point, suggesting that a possible process is starting and causing the crash.
Not used XP in a diagnostic way for a while, but if you can, boot XP into safe mode (if you can still do that) and see how far you get. If it's okay, it would suggest it's a software problem not a hardware one. If I have read the post wrong, my apologies.
chuckalicious
Visitor
Ignore the last post. Obviously not a process error.
