My battery is nearly dead
SOLVED
profile.country.en_GB.title
Ioke2011
Visitor
My battery for my Sony VAIO (VPCEB3F4E) is almost dead and I need some advice on what battery to purchase to replace it.
Thanks in advance.
Tags (3)
1 ACCEPTED SOLUTION
Accepted Solutions
rich912
Contributor
Hi loke2011,
Your safest, but not necessarily cheapest, option is to purchase a genuine battery from Sony.
We are aware that some replacement batteries simply don't work or require a BIOS tweek that in some instances has bricked the Vaio.
Your model was shipped with a VGP-BPS22 battery which can be purchased directly from Sony.
http://www.sony.co.uk/product/vaio-batteries/vgp-bps22a/compatible-products#tab
Your particular model is not in the list of supported products and although I am sure that this is the correct battery it may be prudent to contact your local store for confirmation prior to placing an order.
Rich
Go n-éirí an bóthar leat
1 REPLY 1
rich912
Contributor
Hi loke2011,
Rich
