Hi I've got a VGN-AR41E and I put my MMC memory card from my phone, into the slot, becuase on My Computer it said SD/MMC but now it won't come out.
Is there anyway I can get to this or any ideas? THanks
Hi naVA
I have had a look at the spec for your pc and cant find any mention of MMC slots
I wonder if you have used the Sony slot by mistake. How much pressure did you use to get it in there?
It may sound silly but is it all the way in? Have you tried tweasers?
