GRZ 515G Ram
davos
Visitor
GRZ 515G Ram
I've read that 512mb is max ram for the grz 515g.
Is this true? seems unreasonable
I edit a lot of movies and need more ram!
thanks
Davos
1 REPLY 1
profile.country.en_GB.title
robpaxton
Explorer
Sony advertised that the GRZ500 series has a max. memory of 512MB but it wouldn't be the first time they got it wrong. You could download Everest Home Edition and check what chipset is being used then compare this with the OEM spec. to see if the chipset supports more memory,
You may find that it supports more memory but of course any upgrade you do on the basis of that info. is at your own risk.
