Is it normal for this notebook to get very warm in and around the mouse area?!
No. it's not normal...
Could you download the software EVEREST Ultimate Edition (Trial Version) just to take a look about the temperature ?
Please, write here the results... :smileygrin:
I just bought it yesterday it is my first Vaio ....i've also notice that the ac adaptor is very hot ...Should i go back to the store with him?!
Hi Gaguaza and welcome to Club Vaio.
Those temperatures look normal to me. I think it is normal for your Vaio to get hot but if you are unsure then ask the shop to check it for you.
With modern CPUs and GPUs most laptops do generate quite a lot of heat. Make sure the air vents and the fan are unobstructed.
It is normal for the AC Adapter to get very hot - they all do that.
Hi Gaguaza,
I agree with Blecongo, those temps looks normal to me.
Your laptop temperature also depends the ambient temperature.
My FZ11Z got even higher temperatures.
So... no worries! :smileygrin:
Yes, the temperature is absolutely normal :smileygrin: .
Relax and enjoy your new Vaio. :smileygrin:
U can close the thread 10x all !! I found out that it was very hot in the room i was keeping my notebook that is why i had this problem with the AC on i had no problem!!
You know you can get Everest Home Edition on some download sites?
This will show you the HDD temperature, or even better, PC Wizard (thanks to Blencogo for pointing me to it)
