Fan is too hot..
SOLVED
profile.country.da_DK.title
keerthikan
Visitor
Fan is too hot..
I have an VPCEB1S1E/BJ, but the problem is that  the had begun to be noisy... it runs all the time, and I am affraid that the computer maybe too hot.. i used a program called speedfan to measure the heat inside my notebook, and these is the results...
these is takin yesterday, while i saw i video, and played a game in window mode..
and
these pic took i today
http://www.myupload.dk/showfile/r64317090ef0.png
this is while i saw i video in window mode
http://www.myupload.dk/showfile/r64317290ef0.png
and
this is while i see a video and play a game in window mode
1 ACCEPTED SOLUTION
Accepted Solutions
Blencogo
That's for you to work out.
Common sense would say put it on a hard surface about the same size as the Vaio while on the bed so air can get in the vents.
11 REPLIES 11
Blencogo
Those temperatures look normal to me - I would expect a modern processor to operate between 60 and 65 degrees in normal use and to reach 70 degrees during heavy gameplay.  The CPU would continue to function normally up to 90 degrees when it would begin to thermally shut down.
Similarly, the CPU does not seem to be overcooled - so the fan usage is obviously needed.
Everything seems normal but it is possible that increased fan speed could be caused by dust or debris in the cooling vents.  You could try a can of compressed air to try to gently dislodge any dirt in the vents.
:thinking:
Blencogo
On a soft surface, you may be blocking the vents where the air is drawn in - even if the vent out is clear.
What model Vaio do you have ?
keerthikan
Visitor
It kinda seesm like when i lay on the bed, the laptop becomes hotter, eventhough i didn't cover  for the heat air came out.....
now are the laptop on my desk, and when a take the same test,
Dos  game in window mode, and video window mode,...
is the temp. between.                  50-60 degrees..
keerthikan
Visitor
SONY VAIO VPCEB1S1E/BJ 15.5"
Blencogo
You must make sure all the vents (1) are not covered:
keerthikan
Visitor
is there anyway to use it on a soft surface.. ?
Blencogo
The vents must be unobstructed to avoid damage.
keerthikan
Visitor
well.. how do i do that ?
Blencogo
