hi all
i have a probleme with my vaio dvd palyer;
i cant read or write dvd into my vaio !!
what can i do ??
pls help:smileycry:
Arreter de poster en double, ca aiderais!
Oui, t'as poster en double, un reply a l'autre poste.
Qu'est ce que tu as changer depuis ca ne marche pas?
You should setup nero and you have to know your dvd support what kind of dvd.
thanks but the brobleme that i have is that i can read dvd !!!
I have the same problem, 😞 looked on the forum and its seems to have something to do with sp2, think your ment to upgrade firm where before installing sp2 otherwise theres conflict.
let me know if you find a solution I'll keep you posted on my progerss.
Andy
