Hi guys,
On my new VGN-A215Z laptop, I need to create the recovery disks...
But everytime I try to do it, its says the DVDs are not the right format. I've tryed DVD-R, DVD+R, DVD-RW, but they all say the same thing. I can create DVDs using Nero etc...
Whats going on?
Thanks
Matt:smileysad:
Call VAIO-Link on Wednesday
Thanks, do you have the UK number to hand?
Phone No : 0870 240 2408 (0.07 GBP/min**)
Fax : 0870 240 2409
Hi Matt,
In case you have found the solution to the issue, I would appreciate if you could let me know. I am facing exactly the same problem on my new S2XP VAIO laptop.
You can reach me on jai_boss@hotmail.com
Regards,
Jay.
