change my cd player on a RX406
burnett
Visitor
I want to change my cd player on a RX 406 to a new dvd writer, but i don't know how to access to them.
Thanks
2 REPLIES 2
madxbri
Visitor
Hi i changed mine just unplugged and made sure the jumpers on the back are set to the same settings and plugged the new one in and then ran the driver cd no probs
hope this helps you
Twisted-Rizla
Visitor
Make sure you earth yourself properly before you stick your fingers inside though.
So to speak.
