Burning CDs/DVD/s
induct
Visitor
Burning CDs/DVD/s
I want to use B's Recorder Gold 5 but when I load up it can't find the CD/DVD Drive. When I go to options the drive selector is hidden. Any ideas? Are A series DVD drives not compatable with some softwares?
P.S. I don't want to use Nero!
9 REPLIES 9
profile.country.en_GB.title
kee-lo_
Member
Hi
It's missing the ASPI drivers, thats all.
See this
induct
Visitor
Cheers for the reply, installed the adaptec XP32. (does adaptec control drives?)
Unforunately still not working.
kee-lo_
Member
Is that the ASPI layer?
induct
Visitor
kee-lo_
Member
That should be fine.
No idea why that software isn't working...
induct
Visitor
What supplied software should I use for burning DVD/CD's?
My fiends S1XP has something called Drag n' Drop, why don't the A series have this?
kee-lo_
Member
I thought it did...
induct
Visitor
These are the only progams on my PC:
Programs on PC
The A197XP has Drag 'N' Drop according to here:
http://www.vaio-link.com/specifications/specifications.asp?l=en&m=1547
But the A297XP Doesn't
What should I do?
induct
Visitor
Ok found what to use:
"Sonic RecordNow!"
