I Cant seem to upgrade my bios anywhere in the world except a pay site which is quite annoying as i cannot afford it. someone please help as i am a my wits end. my details are as follows.
AMIDIAG Suite tests and diagnoses every hardware subsystem on your PC! A professional tool for developers, manufacturers and technicians.
AMIBIOS Motherboard Identification Utility v 1.4
This file has recorded information useful in identifying the manufacturer of this motherboard. You must contact your motherboard manufacturer for support. For more information on upgrading your BIOS go to www.ami.com/bios.
Note: The BIOS manufacturer in most cases is not the manufacturer of your motherboard.
BIOS String info:
An AMIBIOS ID String Was Detected:
63-0500-000001-00101111-100104-SPDALE_G
| | | Chipset/BIOS Info
| | BIOS Build Date
| Manufacturer ID
BIOS ROM Information
AMIBIOS ROM Size: 512 KB
BIOS Build Date: Oct 01 2004
Motherboard Manufacturer Code: 0001Not listed in MAN.DAT file
AMIBIOS Build Tag: MUKA1026
AMIBIOS Project ID: MUKA1026 Not listed in TAG.DAT file
SMBIOS info:
Manufacturer : ASUSTek Computer Inc.
Product Name : P4SD-VL
Case Code :WTM20070629246518275
Our system has received your mail enquiry. ASUS Technical Support Engineers will be responsible in replying your mail within 48 hours on Mon~Fri (except public holiday). If you have not heard any response from ASUS TSE, please check for mail reply status from the link below. Thanks very much.
http://vip.asus.com/eservice/techmailstatus.aspx?ID=WTM20070629246518275
Hi Rizzie,
What is your Vaio model name ie FE41S..?
You can find this info either on your Vaio or in Start > All Programs > Vaio Control Centre > System information..
Edit: I have removed your Serial number from the above post, it's not a good idea to post serial numbers on a public forum..
yes it gives me a completly different model no my board is p4sd-vl serial numbers as follows 28*******-5*******. try it its no good. maybe the board it gives me 4 the numbers is o.k.?
Edit: itnot a good idea to post your serial number on the forum..
Go to "C:\Program Files\Sony\VAIO Control Center\VCCSystemInfo"
This should display both your model number and current BIOS versin.
Hi Rizzie,
Is you Vaio model not a PCV-RS402..?
If not what model Vaio do you have, ie FE41S..?
Well with that motherboard it has to be a desktop so a suggestion of moving the thread out of the notebook section?
If you follow the instruction above "C:\Program Files\Sony\VAIO Control Center\VCCSystemInfo.exe"
Then you will see the picture attached. What does it say next to Model number and BIOS?
I think this OEM P4 was only fitted to the PCV-RS4xx/5xx Desktops: -
PCV-RS500C MUKA1xxx 63-0500-000001-00101111-100104-SPDALE_G-MUKA1026 P4SD-VL AMI 8.00 core (Asus)
PCV-RS510 MUKA1xxx 63-0500-000001-00101111-100104-SPDALE_G-MUKA1026 P4SD-VL AMI 8.00 core (Asus)
PCV-RS530G MUKA1xxx 63-0500-000001-00101111-100104-SPDALE_G-MUKA1026 P4SD-VL AMI 8.00 core (Asus)
