after nvidia update...
catstone
Visitor
hi,
after updating my nvidia go 7400 with the latest sony update windows will not shut down correctly (XP+SP2)
i tried some other xp versions (professional, unattended) but still the same problems...also the standby or restard option does not work!!
anybody had the same problem??
2 REPLIES 2
profile.country.en_GB.title
tonybeard
Explorer
Welcome to the forum,
Hopefully your system restore is still working. Go to the control panel>perform and maintain and on the left side you will find the system restore. restore to a time before you updated the graphics card.
catstone
Visitor
thanks tony, i did it and it works i know, but i need the new driver update because some progs are not working correctly with the old driver!!
