Sony KD-49XG7093 - Status top two lines of display when input changes
SOLVED
briduffy0
New
On the above model the screen shows
HDMI / ARC  Tuner 1 (Manhatton TR-3)
Stereo Dolby Digital Plus 3840x2160p
 I suspect It is supposed to show this status each time the input channel changes but due to the way the catchup apps work on my Manhatten recorder each advert causes the status to be displayed.  Very annoying/  Any idea how I can disable this feature.
Tags (1)
1 ACCEPTED SOLUTION
Accepted Solutions
Piscie
Hey, try to follow the steps mentioned here to disable the info banner.
1 REPLY 1
Piscie
