I have a KDL-55W829B and have been using the Plex App very successfully. Recently, the App has stopped working with the message "This application has been disabled because of reported problems"
Are Sony looking to fix this problem?
Hi petkent44,
I'm just going to try to find some answers for you. In the meantime, maybe someone else in the community might have some ideas.
Thanks,
Pascale
Hi petkent44,
I believe this error message probably means that the app is now terminated on this TV. But I'll try to pass this feedback to Sony for consideration if possible.
All the best,
Vanilla_
thanks
Di you get a reply from Sony?
