Discoloured bar on bottom of screen
hopemaniac
New
Anybody have this discoloured bar at the bottom of their screen
Tags (1)
4 REPLIES 4
Piscie
Hey @hopemaniac, what is the model number of this TV? and software version? Also, are you able to see this discoloured bar on everything or just this content?
hopemaniac
New
hopemaniac
New
10 years old so probably past its lifetime, green and red sweeping across the bottom of the screen
Anonymous
Not applicable
Hey @hopemaniac
Yes, probably it needs an inspection. But you can try the basics like disconnecting any externals and disconnect the TV from the mains and check again
Then try to factory reset the TV, if that didn't work, it needs a repair
