Apps on my sony KDL-40W605B
Howami1
Explorer
Does Sony ever update the available apps on this generation of TV. If they don’t does anyone know how I can do it? Or do I need another device? If I do it’s not such a smart TV is it
4 REPLIES 4
LightFoot
Specialist
Hi @Howami1   You would be better off adding a streaming stick containing all the latest Apps.
Howami1
Explorer
It was pointless buying a Sony smart TV. I might just have gone out a purchased a plug and play stick in the 1st place.
Sony should have developed a new software download to upgrade this generation tv. when it decided to no longer support developing new apps for it.
Poor customer support from Sony.
Very disappointed.
It is a seven year old set, what do you expect? Even apple iMac are not supported that long
Joe_Dohn
Specialist
Even if Sony did release an update for it or the apps continued to work, they would be either a slow mess or a shell of what it once was due to the set being too old to run it (if not right now, then at some point), that's why the sticks exist as a product in the first place, easily replaceable and relatively cheap compared to buying a whole other TV.
