xperia sp behaving strangely when connected to pc
SOLVED
tunir
Visitor
whenever i connct my phone to pc via usb it behaves strangley and the touch functins do not work properly what to do??
1 ACCEPTED SOLUTION
Accepted Solutions
rvsiva17
Visitor
That's Cool. You may have the problem If you use some Local Charger/Data Cable for charging.
You'll not able to Use you rphone while connected.
So, Pls Use Original Cables for Charging. It's Always Good for Your Battery and Phone's Life.
Mark as Correct/Helpful AnswerIf U Feel So Slightly_smiling_Face
Regards,
Siva.
7 REPLIES 7
rvsiva17
Visitor
Are You Using Proper Data Cables (Provided with Handset) or Other Data cables..???
tunir
Visitor
ya i am using proper cable,
nyway thanks the problem is now solved after i did a factory reset and update to latest firmware.
rvsiva17
Visitor
Regards,
Siva.
Uliwooly
there are some touchscreen issues with the Xperia SP, you should stop by a Sony repair center
tunir
Visitor
with the recent update i think it is fixed,what u say do u still face the problem after the latest update??
Uliwooly
I don't have this particular Xperia
tunir
Visitor
ok thnks
