why i cant change my screen lock.
SOLVED
Cheng
Visitor
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
18 REPLIES 18
Uliwooly
that's odd, set a pattern lock > then remove it > restart your phone and try again.
Also make sure that you do NOT have any of this apps
task killers
task managers
antivirus
battery apps
ram apps
booster apps
remember if you another lockscreen app it might be creating this issue.
Don't forget to mark the Correct Answers & Helpful Answers
Cheng
Visitor
thank you
Uliwooly
if you still have issues, you could always repair your phone
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
PC Companion (PCC)
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Cheng
Visitor
but how can i remove the pattern lock... i have set a one already and each time i click on it, it ask me to set one again
Uliwooly
that's quite odd, do you have a SIM lock? if you do remove it, if nothing works, then backup your phone and repair it with SUS
Cheng
Visitor
OMG... it now lock my phone and i need to get PUK code, what can i do .... i bought this phone from the sony website.
Uliwooly
in some countries even SIM free phones are network locked, PUK codes are only for Carriers/networks, so you have contact them to unlock your phone
Cheng
Visitor
the sim network company?
HussainQuadri
Contributor
I think you need to deactivate any andministrator apps (Settings - Security - Device Administrators - untick all).
Oh and hold down power and volume up button for ten seconds, remove SIM then reboot to get pass SIM lock.
