recently updated to jb for xperia s, and i had some problems. first, force closes when i try to select a wallpaper for my lockscreen. second, no jellybean easter egg. third, i cannot reset my phone anymore! i have to reset it to re enable all the apps that i have disabled on the ics version. this is a major problem for me! lots of bugs, most apps not working well and i dont know why! i will try to software repair it, but if it still doesnt work... you guys need to find ways to fix my phone or get me a new one. this is bad support, really bad!
Solved! Go to Solution.
You realise they're not even going to read that? That just looks bad.
Also, cool tags lol
thanks for the info. i already did a software repair, but wasn't able to do it awhile ago since i was out the whole day. i basically had many problems, especially the notification bar when it disappeared. i also cannot send or receive files thru bluetooth and nfs. but after the software repair, it worked fine. i really plan on deleting all my data to see how fast this new update works.
