Hi
I am having problem with my xperia U it's turning on but then aftr that it will again switched off i tried to removed the battery for how many times but nothing happen it's still the same what should i do i cant repair it through Pc Companion please help me
how can i update if its off?
Sony update service needs the phone to be off when you connect to it.But the battery should be at least 50%.
ok ill try thanks
Keep us updated,tinkerbell:smileytongue:
Thank you so much,i can use my mobile now
You are welcome.
same promblems with my xperia u..but when i update..an error eccurs..
