throw off calls
SOLVED
MarchJJ
Visitor
throw off calls
Hello!
I've got a problem with my Xperia P, which I bought in July 2012. All the time I used the smartphone, it throws off about 40-50% of incoming and outgoing calls by itself. SIM card works without any problem in my previous phone. I tried to return the smartphone, but according to conclusion of quality inspection, device is non-fault. What the problem could be? The software is of the latest version and it had been repaired to factory setting.
1 ACCEPTED SOLUTION
Accepted Solutions
MarchJJ
Visitor
SIM is original, it was not cut, all settings are as factory. But I can't use phone for intended purpose.
3 REPLIES 3
Sagar
Visitor
Did you buy an original micro sim or cut your mini sim to micro sim?
Uliwooly
I agree with Sagar, just get a brand new MICRO SIM card
uninstall antivirus and/or taskillers and try again
Don't forget to mark the Correct Answers & Helpful Answers
unrelated topic, if you have some time please check this thread
http://talk.sonymobile.com/message/244522#244522
MarchJJ
Visitor
