STUPID QUESTION HERE.
SOLVED
Kalog
Visitor
How can i close or exit an application, that im not using?
When i close some of my apps, i think my apps just go minimize and still eating my memory.
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
when you exit and app or game press Back until you exit, your phone will eventually close this app/game completely as it needs more RAM, do NOT use any taskillers as this will stop the app/game BUT it will make android unstable and sometimes certain apps will run in the background by stopping them wont do any good as they will reopen soon after, thus draining more battery.
3 REPLIES 3
Uliwooly
Kalog
Visitor
i see. Slightly_smiling_Face
i recently remove my task killer. as many user recommend to remove it.
thanks mate!
Uliwooly
anytime, another suggestion
do NOT install any
antivirus
ram apps
booster apps
battery apps
this will create issues and drain your battery
