I have recently bought a New Xperia Ion LT28h & i am new to Android, here i want to assign different songs to different contacts which was possible in my previous mobiles like N72, N95 & N97. I also saw assigning in the contact, but every time i select a song & assign, it shows only default. Is there else where i have to change any settings to reflect different songs assigning?
Secondly i want to call a contact by saying the name, is it possible here?
Other thing is i want the phone to say name when it is ringing, i thing it is possible in Talk back, but i dont want it say all the other programs to speak, i want only to say the caller name or number.
can somebody help me.
Regards
S. Sathish
Solved! Go to Solution.
you can use Vlingo
Don't forget to mark the Correct Answers & Helpful Answers
unrelated topic, if you have some time please check this thread
you can set an specific ringtone
phonebook > select a contact > menu > edit the contact
although it's easier to use an app
http://talk.sonymobile.com/message/244522#244522
you can use Vlingo
Yes that is what i did, when i go to edit & see assign a ringtone, i am able to select a song & it plays then i clicked done & came to see only default ringtone. am i making anywhere mistake, pl guide....
Thanks & Regards
you have to press Done twice
if i press done once, it goes back to the previous page ( ie contact page)
that means i am unable to do it twice.
Is there any where lese option exits?
that's odd,
phonebook > select a contact > menu > edit the contact > ringtone > select the ringtone > Done > Done
