restore message icon
SOLVED
Billa
Visitor
Hi, I accidently deleted the message icon from the toolbar at the bottom of the home screen of my xperia neo v. is there a way to restore it. thanks
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
open the app drawer > look for the messaging app > tap and press it (long press 1 or 2 seconds) it will vibrate > drag it anywhere on the screen or the bottom bar
Don't forget to mark the Correct Answers & Helpful Answers
unrelated topic, if you have some time please check this thread
http://talk.sonymobile.com/message/244522#244522
3 REPLIES 3
Uliwooly
Billa
Visitor
Thank you so much Uliwooly for your reply, It works perfectly Slightly_smiling_Face I really appreciate it.
Uliwooly
I know, I'm awesome
