Ram capacity question
Ntasuto
Recently I entered on my xperia sola the running applications and I noticed a strange thing about the ram.
Below the apps there was a bar which showed the free and used ram.
It was 159 used and 140 free, so my question is : where are the rest 201 mb or ram????
Wasnt sola supposed to have 512?
I know it may not be exactly 512 but 200mb less is kinda too far .
Are the 200mb used to run the android OS and the vital processes or it may be a faulse in ram?
I would really like to know if there is anything wrong with my ram or everything is ok.
Thanks in advance
Ntas
profile.country.PH.title
MarlonUk1
3 RISPOSTE 3
devasola
Yes, please answer the above question. Even I was wondering whats wrong with the RAM capacity!!
MarlonUk1
you got your answer.
MarlonUk1
