Hello,my phone sony xperia go, I have a problem, build number 6.1.1.V.1.10, I can not upgrade to 6.2.A.0.400, connect your phone via USB, run through the PC Companion software version 2.10.155 (Prod 29), but the program says that "recently, the software is already set as "what to do, please help! I live in Russia, Samara, s\n CB5A1L9RUZ
Solved! Go to Solution.
you have 2 options
1) wait for the update to be released in your country
or
2) manually update your phone
Don't forget to mark the Correct Answers & Helpful Answers
And where I can find firmware to manually update? Which I update the firmware? Will this firmware suitable for my region? How long can I wait for the release of firmware for your region?!
you are not going to find when is the update going to be released in your country
this is how to manually update your phone
http://talk.sonymobile.com/thread/41609
