miro
SOLVED
wendyilejay
Visitor
miro
hi.
i hae a problem with my sony xperia miro.. i accidentaly falls my ph to the floor. and now i can't use the touchscreen to unlock it and i ca't do anything/.. the touchscreen won't work..
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
there's nothing you can do but to replace the digitizer/touchscreen
you have to options
1) pay Sony to replace it
or
2) replace it yourself, which its a lot cheaper BUT you will void your warranty
http://www.sonymobile.com/global-en/support/contact-us/
Don't forget to mark the Correct Answers & Helpful Answers
1 REPLY 1
Uliwooly
you have to options
or
