problem with network cuts after call
utkarsh3346
i ve problem in my sola dat it cuts network fr 5- 10sec. after every call whether i receive, make a call or even had a missed call
its pissing me off
pls help
utkarsh3346
i ve found d solution dat hs nothing to do wth sim
i had been using wcdma(prefered)/gsm in network selection
i changed it to gsm n nw dere r no network cuts
10 RISPOSTE 10
Uliwooly
do you have a sim lock? is your sim card older than 1 year? can you test a different sim card?
do you have any antivirus or taskillers?
Don't forget to mark the Correct Answers & Helpful Answers
unrelated topic, if you have some time please check this thread
http://talk.sonymobile.com/thread/44888
utkarsh3346
i ve avg free version app
n my sim card older than a yr
i ve tried other sim card
Uliwooly
get a new SIM card and also uninstall your antivirus, you don't need them, this is an android not a pc Dizzy_Face also as long as you download apps from the playstore you should be fine, just keep an eye on the permissions apps require
utkarsh3346
well i ve uninstalled d antivirus bt still the problem persisted n i dont think it is related to my sim card
Uliwooly
Can you get a brand new SIM card?
utkarsh3346
as of now no bt i ve checked dis problem using different sim n its dere in all of dem
Uliwooly
just try with a brand new SIM card
utkarsh3346
Petter
Appassionato
Glad to hear it sorted out (as far as I understood)! Slightly_smiling_Face
http://soundcloud.com/kyson/bon-iver-holocene-kyson-remix
