Problem: Silent mode automatically turning off
SOLVED
yasirniazkhan
Visitor
I have a very annoying problem with my Xperia Mini. I put it in silent mode, but it comes out of silent mode every half or full hour. This is really embarassing during meetings, etc. This was the problem in original android. Then I upgraded android to 4 ICS. After the upgrade, it was more stable for some time, but now the problem has started again. Does anyone else have this problem? And what is the solution?
1 ACCEPTED SOLUTION
Accepted Solutions
gwhispererz
Champion
It could be conflict with app(s) that you have installed. See if you are able to locate it ....
12 REPLIES 12
gwhispererz
Champion
Hi, if you are sure that you did not inadvertently press the volume rocker, suggest you software repair phone with Sony Update Service. Here's the download link, http://www.sonymobile.com/gb/tools/update-service/. Be aware that this process will erase phone data completely.
yasirniazkhan
Visitor
Hi. Thanks for your reply. Doesn't upgrading the OS repair the phone?
btw, what is the volume rocker? Is it the volume keys on the side of the phone?
gwhispererz
Champion
Yup, the volume key.
Normally a software repair will resolve a software glitch ....
yasirniazkhan
Visitor
I downloaded the software and repaired my phone. It worked correctly for 2 days, but then the problem started appearing again. Now it again turns the silent-mode off almost every hour.
gwhispererz
Champion
simplysim
Visitor
whenever I have my Xperia S in silent mode and a message or phone call comes, it turns off the silent mode after that call or sms. this is very frustrating. Any idea why this happens?
gwhispererz
Champion
Hi simplysim, have you tried repairing phone software? Just be aware that this process will erase phone memory completely.
yasirniazkhan
Visitor
Yes it was an app that was causing this problem. I uninstalled it and installed another similar app. Now this problem does not occur anymore. Thanks for the helpful hint.
gwhispererz
Champion
Great!
