Problem facing with ICS update
SOLVED
MihasRhmn
Visitor
During updating my xperia Sola I am having a problem. During installation a stage comes where all the files get downloaded and start the installation but after some time it's stop & a window show that reconnect your phone by charging full. And the update stop & my Sola restarts but it's hang showing the sony logo. I try to  restart it by hold the power button & both volume button & also try to hard reset it but again it hangs showing the sony logo. Can anyone help me to solving this? Slightly_frowning_Face
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
just try my above suggestion (30min) and then repair it with SUS
Don't forget to mark the Correct Answers & Helpful Answers
unrelated topic, if you have some time please check this thread
http://talk.sonymobile.com/message/244522#244522
6 REPLIES 6
Uliwooly
Charge your phone (wall charger)
then use SUS instead of PCC
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
http://software.sonymobile.com/install_packs/Update_Service_Setup-2.12.12.41.exe
MihasRhmn
Visitor
When i connect to the charger nothing is showing that it is charging or not.
Uliwooly
does the LED turn on?
try this connect it to the wall charger > press and hold volume up and power for 6 seconds > let it charge for 30min then use SUS on your computer
MihasRhmn
Visitor
no, the LED is turn off.
i try what you say but the LED did not turn on. Slightly_frowning_Face
Uliwooly
MihasRhmn
Visitor
Hmm, thank you for your help Slightly_smiling_Face
