On the X10 Mini Pro I had a build-in, plain and simple note app. I really miss that one. I have tried to find a plain and simple replacement to work on my new Xperia Mini Pro (SK17i). But I can't find anything plain and simple. It's all bloated out of proportions like some office app. All I need is to write a little reminder to myself once'n'awhile.
Where do I look?
Ok, I got it
http://forum.xda-developers.com/showthread.php?t=1331481
make sure that you mark the Correct & Helpful Answers
you can try evernote or note everything from the android market
you can also try to do list...
Both "evernote" and "note everything" are too bloated. I need a really plain and really simple note app, just like the one in X10 Mini Pro.
"To Do List" is not the kind of app I'm looking for.
What I need is a way to make a tiny note of a phone number, a book title or something similar. I don't keep notes forever. I don't want a bulky program that needs a lot of ekstra work before a note can be added. Just very plain and very simple. The functionallity was a part of X10 Mini Pro. That's about the only thing that I really misses from that phone.
Note Pad
ColorNote Notepad Notes
InkPad notepad
"Note Pad" needs a title. That's not plain and simple.
"ColorNote Notepad Notes" and "InkPad notepad" are both bulky and definitely not plain and simple. The "notes" app in X10 Mini Pro was very plain and very simple. I want that functionallity back... 🙂
what was the name of the note pad you had before?
Ok, I got it
Thanks. I have been looking all over the internet for this tiny piece of software.
Thanks again... 🙂
great...
