Neo V Update from 2.3.4 to (4.0.2.a.0.42) MTP ISSUES
SOLVED
Not applicable
Neo V Update from 2.3.4 to 4.0.2.A.0.42
I tried to connect via pc companion and everything went well for the first time..at the last moment during the MTP connection a crash message came with Win 7 hence PC companion had a close
Since then i am unable to connect via MTP and it says no phone connected, but via MSP it connects happily
So now stuck... unable to update to 4.0.2.A.0.42
Please Advise Thinking_Face
1 ACCEPTED SOLUTION
Accepted Solutions
no, Ice Cream Sandwich is not available, there is only ONE phone in the whole world that has Android 4.0, and that is the Samsung Galaxy Nexus. we will get 4.0 later on.
9 REPLIES 9
Make sure you backup everything
Backup & Restore app
Use this links to download the apk
http://forum.xda-developers.com/showthread.php?t=1193802
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
http://www.mediafire.com/?1n07llajeaoo03y
How to install it
You need to
go to settings -> applications -> check unknown sources
download IO File Manager
https://market.android.com/details?id=org.openintents.filemanager&feature=search_result
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
just to play it safe sync your contacts w/ google if you haven't already
open your phonebook
press MENU button -> tap on Send Contacts -> select all -> send it to your email
on your computer
-> download the file -> go to your gmail -> click on contacts -> click on more actions -> on the drop down menu click on "import" -> choose the file -> and click import
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
market my library.JPGmarket my library 02.JPGmarket my library 03.JPGmarket my library 04.JPG
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
"backup & restore SMS"
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use "Save MMS"
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
Call Logs
And for call logs this is great
https://market.android.com/details?id=com.yang.android.ansta
Also if the update it's not available in your country/network just yet or if you want to debrand your phone you can manually update your phone
https://market.android.com/details?id=at.abraxas.powerwidget.free&feature=search_result#?t=W251bGwsM...
Not applicable
Now currently trying with Update Service (SEUS) will let you if this is successfull :smileygrin:
if it says that you have the latest update try again but this time remove the SD and SIM cards
if there's an error while trying to download the udpate
turn off your firewall and/or antivirus
Not applicable
@uliwooly-wooly
bro the update went smoothly...
But now the build number shows 4.2.A.0.42
Android version is 2.3.4 only.. am confused that is it not a Icecream sandwitch update??
And pls advise the changes made in this build!!
Not applicable
ah ha... thanks a lot.....My neo v is updated...need to chk the new update is stable...
thanks again for your quick response...
anytime
