Keyboard language problems
SOLVED
Giesji
Visitor
Hi
I recently formatted my Xperia S to factory settings so I had to set up everything again. When it asked me about keyboard language and secondary language, I somehow managed to get my two languages (Danish and english) mixed up.
I use to have a button on my keyboard to I can manually switch between the two languages, but now it's both english and danish at the same time. And thats a problem!
I would really like to have the button back, so I decide if the dictonary is either english or danish, and not both at the same time.
How can I change this?
1 ACCEPTED SOLUTION
Accepted Solutions
Henke
Contributor
Ok, if you go to settings, Language & Input, go to settings for Xperia keyboard. Select Writing languages, have you selected your languages here?
If you only select danish and english it should work and you will have the globe-button on your keyboard so you can switch between them.
4 REPLIES 4
Henke
Contributor
First make sure you have selected the correct keyboard:
Go to messages, create a new message, tap on the white text field, pull down the notification bar, tap on "Select input method" and choose "Xperia keyboard."
Let me know if you are still having this issue.
Giesji
Visitor
It is the Xperia keyboard already. Anything else is either Japanese, Chinese or Google voice.
Henke
Contributor
Giesji
Visitor
It worked! Thanks Slightly_smiling_Face
