I have tried software update and now i can not turn on my phone. what should i do?
SOLVED
Not applicable
I tried to update my xperia arc, using pc companion. Twice, the process was not finalised, beiing an error. After I did quit, i was stupefied! I can't start the phone. When i try to connect it again, pc suite tells me : turn your phone on, and reconnect. I tried to follow those steps(removing the baterry, waiting and turn the phone on), but nothing works.   Can someone help me? Yesterday i had a perfect device, now i have a dead one.
Thank you slim shaddy! I love you, dude:))
1 ACCEPTED SOLUTION
Accepted Solutions
slimshaddy
Hero
http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe
update with this..
this works even when your phone is off..rest the software will tell you.
1 REPLY 1
slimshaddy
Hero
update with this..
