How to use red, green, yellow, blue buttons with new remotes
DanJCobb
Explorer
Just got a newer Bravia with the new remote that has now coloured buttons.
when looking at the tv guide you can use the coloured buttons to select different pages and settings.
how do I access the colour buttons without physical buttons on the remote??
thanks
Tags (3)
6 REPLIES 6
Anonymous
Not applicable
@DanJCobb What's your TV model ?
daveyh64
Enthusiast
What model of Sony TV have you, and was it not supplied with two remote controls?
My Sony TV came with two remotes, one is a cheap plastic remote with many buttons including the coloured buttons.
The other remote is back lit with less buttons.
There is a 123 button which you press that gives you access to further features like the coloured buttons.
So press 123, select Colour you should see the four colour options on screen, select the colour that corresponds to the task you want to perform.
DanJCobb
Explorer
Its a KD55X85L
And yes - you reminded me - it did come with 2 remotes which I thought was weird.
The second remote does have the colour buttons and tons of smaller ones - pretty ugly really!
I much prefer the look and feel of the other one - with the minimal design and buttons.
But the nicer remote doesn't have the 123 button you mention
But I now guess we do have an option to choose a colour button if we really need to
daveyh64
Enthusiast
Yes as your TV is newer than mine, the 123 button on the metal remote is now the Menu button,
this should give you access to the onscreen menus which should include the colour buttons.
Click on the link below to the Sony Support site for your TV, there you can access the online manual, the downloads page and Q&A's.
https://www.sony.co.uk/electronics/support/televisions-projectors-oled-tvs-android-/xr-42a90k/result...
daveyh64
Enthusiast
Oops wrong link in the above post.
This is the correct one for your TV.
https://www.sony.co.uk/electronics/support/televisions-projectors-lcd-tvs-android-/kd-55x85l
DanJCobb
Explorer
Super helpful - thank you
