Recently i downloaded the spb mobile shell apps in google play. When i tried it, the programs ask if i want to always use it when i started the phone. I clicked yes.
But then it went to activating the program, but to my dismay, it said that the programs doesnt compatible. Ok, i think i'll just uninstall it after i restarted the phone. But after i restarted it, the phone always use spb mobile shell after start up. Because the compatibility problem, the start up screen shows blank. I cant access menu to uninstall the program.
This happened everytime i restarted the phone. Without restoring the phone to factory setting, is there anyway to start the phone in safe mode so i can uninstall the SPB program?
Thx in advance guys.
Solved! Go to Solution.
Thx Nabeel
Btw which key is the Menu Key in Xperia S ?
& while my Xperia S reboots again & again, i keep on tapping on the key, how do i noe its working or not, cuz those keys are touch sensative!
Its the option/ menu touch sensitive button ( rightmost )
as soon as you start your Xperia tap and hold on option key/menu key and after sometime you will see safe mode written on the bottom left side of the screen
Well that wasnt happening. So i tried the Repair the phone thing. & It worked. :smileygrin:
So what steps did you take to fix this again? thanks.
Just restart,when you get the xperia screen,keep vol down pressed.
