How to remove SD Card safely ?
VaibhavAds
How to remove SD card from card slot of Tipo?
It takes a long time and there are chances of damage too.
Please tell the exact way to remove SD card easily. If it were like push and pull, it would be a lot easier.
Johan
Master
3 RISPOSTE 3
Michael-J
To remove the SD card you would need to remove the battery from the phone, then press down the small tab whilst you remove the card from the slot.
What do you think about this forum? Let us know by doing this short survey
VaibhavAds
Even after pressing small tab, card can't be removed quickly.
Can you please upload pictures or direct me to link?
Johan
Master
On page 8 in the users guide you can see an illustration of this.
http://www-support-downloads.sonymobile.com/st21/userguide_EN_ST21i_1265-3199.1_Android4.0.pdf
