how to make a screenshot on a Xperia ray?
SOLVED
tintomrobel
Visitor
my phone, Xperia Ray, runs on android 4.0.4. I don't find how to make a screenshot on it? Apparantely combining the buttons 'Power' and 'Volume down' should make it able, but that does not work. Neigther combining the home button and power button or power button and volume up....
1 ACCEPTED SOLUTION
Accepted Solutions
Nabeel
Master
Press and hold power button and volume down button exactly at the same time and  hold them there until you take a screenshot
Don't just hold for 2 seconds but hold them until you take it
7 REPLIES 7
sourabh
Visitor
Yes I am also looking for screenshot option. My previous cybershot phone had that function but missing in Ray.
Jeff
Enthusiast
There are two options:
Ice Cream Sandwich OS: Press and hold both the Power key and the Volume down key for 2 seconds to make a screenshot.
Gingerbread OS: Press and hold the Power key briefly to engage the options pop-up and select "Take screenshot".
Edited: Corrected OS versions!
Nabeel
Master
tintomrobel Please search the forum before posting a new thread. Slightly_smiling_Face
There are many threads on the same topic
And oops, Jeff missed a little thing above, He might be in hurry
The procedure that he wrote for GB os would work in ICS and vice a versa
tintomrobel
Visitor
Doesn't work 😞
Nabeel
Master
tintomrobel
Visitor
Yes! It works! Great 🙂  Thank you very mutch!
sourabh
Visitor
worked
thanks
