heating problem
SOLVED
akshay172
Visitor
heating problem
Xperia U heats up after using it continuously for over 15 minutes. Any solutions??
1 ACCEPTED SOLUTION
Accepted Solutions
iyer_vignesh
Visitor
This is natural.Most of the smartphones heat up due to use of heavy apps.Factory reset should help.You may also try updating to ICS
1 REPLY 1
iyer_vignesh
Visitor
