Error while updating to 9.1.A.1.141
pradeesh_p
I am getting the below error while updating to 9.1.A.1.141 using PCC. Has any one knows why this error?
Uliwooly
disable your firewall and/or antivirus and try again
7 RISPOSTE 7
Uliwooly
Uliwooly
or you can try with SUS
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Don't forget to mark the Correct Answers & Helpful Answers
Uliwooly
is your bootloader unlocked?
pradeesh_p
I  think no. sorry.. am not much aware of bootloader. I updated the last version 140 same this way only thru PCC without any problem.
Uliwooly
does SUS work for you? have you disabled your firewall and antivirus?
pradeesh_p
I disabled both but same problem. My doubt is I am getting the error due to the slow internet connection. Its less than 500kbps now. I will try when I have 8 mbps or more speed.
Uliwooly
keep us updated
