My phone was working perfectly until I was prompted to update my phone to Android 2.1.1. yesterday. Since then, each time I try to look at my inbox, the application crashes with this message
The application Email (process com.android.email) has stopped unexpectedly. Please try again.
I've checked and changed some of the mail settings but can't find any way to stop the process crashing
Is there a fix or a workaround or should I (indeed is it even possible to?) roll back to the previous version of Android?
Thanks,
Suzanne
Solved! Go to Solution.
Now after all the factory reset and firmware reload, I'm getting the problem again -email is crashing. Smbody Pls help
which error do you get?
force close
reboot your phone if it comes to worse repair the phone with Udpate Service
I tried rebooting and updating using SEUS, didn't work for me
you can try
https://market.android.com/details?id=com.fsck.k9&feature=search_result
or this one its even better
thanks a lot K-9 looks good !!
anytime
