sony Xperia P is having camera problem specifically in 8MP resolution....only centre part of the image is slightly visible... rest of the image is completely black..even in flash... this is comon problem with this model as i had takne replacement once wihtin 6 days of purchase .. but again same problem...
sony design team need to work on this and provide the solution or replacement as its a matter of now quality of product supplied by Sony... I feel they should not give such kind of defective product to the customer and just keep the customer waiting for replacement again and again....
very bad experiance.... better not to buy such kind of product just on brand name...
Solved! Go to Solution.
Read this post http://talk.sonymobile.com/thread/126109. These problems have been discussed before and nothing for now,we are all expecting for JB.JB was told to be the solution,it will fix the camera problem.You could also try taking pictures in 6mpx until then.
even i'm facing the same problem but with only in flash mode when taking nearby pics in close up shots
Please don't start your own new threads on the same problem that has been discussed before. Use a 6MP camera or root your phone and get a custom ROM to fix it or the best solution is to wait for Jelly Bean!
