acro s scratch resistant?
SOLVED
nagaputeh88
Visitor
hello...i've bought this acro s in early september...did the phone has :
#1 SCRATCH RESISTANT REALLY?because it did not! my acro s already have few scratches that have been eyesore to me when I look at the screen...OR DID SONY ALREADY TINTED THE SCREEN? IF YES CAN I REMOVE THE TINT?
#2 WET FINGER TRACKING REALLY?because I think not! when it has water on top of the screen...the phone become crazy... suddenly it do whatever itself...open app drawer itself...etc... DO I MUST SEND THIS PHONE TO CLAIM WARRANTY BECAUSE ITS HARDWARE FAILURE?
#3 CANT MAKE VIDEO RECORDING UNDERRWATER AS ITS PROMO VIDEO IN ACRO S ITSELF (refer to num 2 problem)...
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
indeed, but this shatter proof film it's quite difficult to be removed, just be extra careful and patient
Don't forget to mark the Correct Answers & Helpful Answers
unrelated topic, if you have some time please check this thread
http://talk.sonymobile.com/message/244522#244522
11 REPLIES 11
Uliwooly
1) the glass is mineral glass scratch resistant it has a film (shatter proof film) that it is NOT scratch resistant, chances are that the film it's scratched not the glass.
also, scratch resistant it is NOT scratch proof
nagaputeh88
Visitor
so.....,,can I remove that film? and how about my problem num 2 n 3?
profile.country.PH.title
MarlonUk1
1.) what uliwooly said
2.) how much water are we talking about? remember its just WET Tracking not SUBMERGE tracking
so you can use the screen with a little sweat or a bit of drizzle rain
3.) the trick is how to postion your phone so that the capacitive keys would not detect the water as a command.
---- start your video recording before you submerge the phone , try a variety of positions in submerging the phone, do it on angles or do it fast.
----- taking photos underwater is easy with the use of the shutter key
MarlonUk1
about the film, just make sure to have a replacement before you remove the screen protector,
nagaputeh88
Visitor
film replacement? you means that i can remove the film and replace it with any ordinary screen protector at any phone shop?
Uliwooly
nagaputeh88
Visitor
why we must be careful when removing the film uliwooly?how do you mean the dificult to remove the film? n if I wanna replace it with a new film, where can I buy it?btw... thanks a lot... im proud to be in sony family...use sony phone since 2008... Slightly_smiling_Face
Uliwooly
you can get them online, invisbleshield if the scratch it's not that bad, you can just place a scratch resistant film on top of the current film, it should hide the scratches.
check ebay, amazon or your local sony store.
MarlonUk1
you can also check out skinomi. Slightly_smiling_Face
