Xperia M2 touchscreen not responding
AbiH
My new Xperia M2 is not responding from the touchscreen.  The buttons on the side are working but touchscreen not reacting to anything.
I can't go through the sony Smartphone update service because i have to switch the phone off before running it and I can't switch off the phone without the touchscreen.
It's Sunday so struggling to get any technical support.
Any ideas?
Thanks
AbiH
I've done this and phone now won't switch back on and no light is showing when I plug  it in to charge.  It had plenty of battery on it. It seems to be completely dead.
36 RISPOSTE 36
Thommo
Hold volume up and power for around 10 to 15 seconds or under one of the flaps you may find a small red reset button - Either of these will shut down your phone - Try restarting to see if the issue is resolved if not then contact Sony http://www.sonymobile.com/global-en/support/contact-us/ care or take it back to the place of purchase
AbiH
AbiH
I just repeated the restart  process and it's come on and the touchscreen is working again.  Thank you
Whitehouse
If this happens to to others, I just took out my sim which turned my phone off ,then when I put it back in it worked again.
via
I almost cry coz this happen to my phone, ,, but I dont lose hope I try to search some answers,,, and then this forum appears
,,, thank you so much it really helps a lot, god bless,
dubyk81
Thanks holding volume and volume up worked great. Nice one.
GEADS
HI, your pose is very helpful. it worked out on your phone so with us. Kudos
sperrin1
thanks the reset worked a treat
luke2man
