Video problems
Bob12
Visitor
Video problems
I have a problem in playing video on my xperia m4 aqua, not only in album but also on youtube (app) or dailymotion (in chrome). How can i resolve it?
If i make a video with my camera it looks black with audio,, and older videos i had on my sd are played slowly and with lag
48 REPLIES 48
Janree
Visitor
Thanks! It works! Grinning_Face
Sneha13
Visitor
It usually happens with me in every 3 days.. Whenever I am using Internet on my phone, suddenly YouTube shows 'sorry something went wrong Tap to retry'. None of the videos works properly on my phone. All the videos hangs and it's very frustrating. I think the problem occurs when ever there is slow Internet speed.
Its a request that you should rectify the problem as soon as possible otherwise it's a very good phone for me.
I also wanted to ask whether the marshmallow 6.0 upgrade would solve the problem.!??
Plz do reply.
TIA
valyo_bg
New
Just to remind: when we have video problems Camera will NOT record video, only audio and at the end, recorded video clip will be with black screen, only sound is available. I loose all my Christmas video clips - no way to recover, black screen ...
valyo_bg
New
It will not help, I write to you on other post. Again you will face same problem with camera, YouTube and FB. I try this solution already at the beginninng, no luck, still problems with black screen ...
To resolve this problem we need official update from Sony.
Chanty1
Visitor
I have the same problem with my M4 aqua. All my videos recorded are black but with audio, and videos online keeps lagging, I reformat my phone once and its okay for one week after that the same problem appears again. I bought my phone last October 2015 and the problem occurs first on november 2015 I ignored it but it appears again early January 2016. Im very disappointed about this 3 months of used and its already broken.
Wlmpie
Visitor
Same problem for me. Phone in use 5 days now , please fix this bug
flandatico
Visitor
@Samuel wrote:
I suggest that you try to repair the phone software using PC Companion..
Before repairing your device you may want to backup your information first. Check out this topic for more information on how to.
How to backup?
These steps didn't work for me. I tryed it and it worked fine for a feel days, but I got the same error again.. 😕
Heskett
Visitor
Hi, I have the same issue as above. I'm on my 3Rd back up and repair. Overall I am thoroughly disappointed with the m4 Aqua. Where can I go to get the issue resolved? Kind regards, Kev
Terasa
Visitor
Thank you so much.  I have struggled watching videos of my grandchildren and nobody could help me but now I realise that I needed to update 'Album' on my phone.
Turbotiff
Visitor
Use file commander to go into internal storage/android/data and delete com.android.youtube. This gets rid of the failed update and allows all videos to play. Don't update you tube or it will happen again.
