Can anyone help?
camera has completely stopped working. I have reset phone to factory default etc to no avail. Does anyone have a solution or process ihave to follow in order to get it working again?
many thanks
That's quite odd, were are you saving your pictures?
Hi there,
Sincere apologies for the long dealy in replying - work is taking its toll.
Pictures and videos were previously being saved in the album folder. When phone is connected to the laptop - i can locate them via the path
internal storage > DCIM folder > 100ANDRO folder
There is nothing in any of the camera, pictures, album, movies, videos folders which i expected there to be.
I have seen today there are other posts relating to same problem being dealt with by Alexdon (i think). Iam going to go and have a look see if there is anything different i can try. I am guessing though that you will have covered pretty much all, but we can always try.
if you have any more options to try, i am your willing guinea pig as its very frustrating - i enjoy taking outdoor pics especially this time of year in the UK with all the frost etc.
Something else i have just thought is the flash stopped working at the same time.
Sincere thanks for your help and really appreciate it
Regards
Andy
I have exactly the same problem in my Xperia E2033 (E4G) phone and also the flash stopped working and then I realized the camera was not working anymore.
Has anyone found a solution for this issue?.
I recall updating the Xperia phone to the latest firmware just before the camera and flash stopped working but I am not sure if this was the issue. Not a good idea to perform Sony updates it seems....
